Acceleration issue, 1987 350 TPI
Old Mar 22, 2011 | 03:38 PM
TheRedGoat's Avatar
Car: 1987 IROC Z28
Engine: 5.7L TPI - Stock/OEM
Transmission: 700r4 - Stock/OEM
Axle/Gears: Berg Warner 9 bolt - Stock/OEM
My 87 Camaro has always had an issue with acceleration. Even with new plugs and wires.
As I hold the throttle to the floor and accelerate through the gears, from zero to 90+ is does not have a smooth 'pull'. It seems to surge/lag in almost a sawtooth pattern as it gains speed. It is not severe, just the sort of odd pattern that you can 'feel' but it is not tossing things around. Almost a subtle 'feel it in your shins' motion.
No knocking, no pinging (with super unl, occasional pings on 87).
No backfiring, no hard starts.
Just a weird acceleration curve. You can feel it the most in the second gear range. But it is present in all gears.
Where do I start to track this down?
TRG
Old Mar 22, 2011 | 03:45 PM
old z mzn's Avatar
Car: 1992 z-28
Engine: 383 stealthram
Transmission: auto
Axle/Gears: 4.10
Re: Acceleration issue, 1987 350 TPI
how many miles....any mods
Old Mar 22, 2011 | 03:46 PM
TheRedGoat's Avatar
Car: 1987 IROC Z28
95k original miles.
Factory original.
No Modifications.
Added to profile just now.
TRG
Old Mar 22, 2011 | 04:13 PM
old z mzn's Avatar
Car: 1992 z-28
Transmission: auto
Axle/Gears: 4.10
kinda had the same problem mine was fuel injectors.
Old Mar 23, 2011 | 08:10 AM
JustCruzin's Avatar
old v mzn is probably right if they are the originals, Also did you do a compression check.
Old Mar 23, 2011 | 09:17 AM
TheRedGoat's Avatar
Car: 1987 IROC Z28
I assume they are the originals. I have no records of them being replaced by the previous owner, but he was not the original owner.
No compression test yet.
TRG
Old Mar 23, 2011 | 11:46 PM
david chambers's Avatar
Car: 1986 iroc Z-28
Engine: "LB-9" TPI 305
Transmission: 700-R-4
Axle/Gears: corporate 2:73-1
i would start with fuel pressure and or delivery
jbd1969
Aug 17, 2015 07:06 PM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
