1970's block with what type of cam?
Old Mar 23, 2011 | 09:23 PM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
Ok I ended up getting a 70's block cast #3970010 2 Bolt Main, machined bored, ect.. I need to know what type of cam and lifters the block can use, hydro. Roller, hydro. Flat tap. Ect and roller or flat tap lifters.
I'll be using it with 1993 heads with 1.5 rockers
Old Mar 23, 2011 | 11:41 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 1970's block with what type of cam?
Originally Posted by Foster382
block cast #3970010
Will be flat tappet cam and lifters stock ; factory roller cam didn't come out until late '80's
Can be converted to a roller cam and lifters but expensive ($300+ for lifters alone )
Old Mar 23, 2011 | 11:47 PM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
I can't just put in roller lifters from my engine and get a new roller cam of does some machining have to be done to it?
Old Mar 24, 2011 | 06:33 AM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
Comp's retro-fit roller setups work well. I had the XR270HR K kit in my '77 350 block and other than having to add pushrod guideplates it worked great.
http://www.compperformancegroupstore...Code=K12-422-8
Little pricey, but it's actually about $300 cheaper now than 10 years ago.
Old Mar 24, 2011 | 01:34 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
You just need to get special retrofit roller lifters. Not that big of a deal. But you definitely cant use factory style roller lifters with the spider.
Old Mar 24, 2011 | 02:02 PM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
How about hydro. Flat tap; would that fit like the stock back then? I wanna keep it cheap and besides it's going to be a 355 Tbi when I finish it, maybe even a Tpi if I feel like doing the wiring.
Old Mar 25, 2011 | 05:47 AM
Car: 1992 Camaro RS
I would strongly suggest going with a roller cam. Its one of my bigger regrets about my build.
The extra power and peace of mind is worth it. If you insist on going with a flat tappet cam at least do some research about zinc levels in modern oils and proper break in procedures.
Jake_92RS
Jan 28, 2020 10:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
gixxer92
Sep 1, 2015 04:32 PM
camaro71633
Sep 1, 2015 10:24 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
