egr valve vacuum line
Old Mar 24, 2011 | 11:17 AM
csimpson1's Avatar
Car: 1984 Black Trans Am
Engine: 350 bored .030
Axle/Gears: Stock. Wanting up grade
where does my egr valve connect to? also where does my o 2 sensor wire to? there are 3 ports on the front of a carburetor where do they go. Pass side to vacuum advance. But what the other two for. Sorry if stupid question. Just want my car to go.
Old Mar 26, 2011 | 07:42 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Re: egr valve vacuum line
Wish I could help ya more, as I have little knowledge of carbs, only FI . For your o2 sensor, it will be a purple wire, and should go from sensor into ecm.
Old Mar 26, 2011 | 08:09 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
The purple O2 sensor wire goes into the ECM harness just to the driver's side, rear of the engine. Do a search for vacuum diagrams.
Old Mar 27, 2011 | 11:01 PM
heinousacts's Avatar
Mine connects to the egr solinoid, not sure if your year has one tho.
Search for a vac diagram for your year and engine
Out-Cast
Sep 3, 2015 09:05 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
