Fuel line fitting size
Old Mar 27, 2011 | 03:18 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Im finally getting around to swaping over to braided steel lines in the engine bay. Anyone know what size/thread the stock fuel line fittings are that connect to the stock rubber lines? I know the supply and return are 2 different sizes, but I cant for the life of me figure out what they are. I got all the stuff to make my hoses minus the 2 adapters I need for those lines.
Old Mar 28, 2011 | 03:03 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: Fuel line fitting size
You can buy the adapters from Aeroquip or Russell. IIRC, they are 14mm and 16mm metric o-ring fuel fittings. You can ask at you local Russell or Aeroquip dealer for GM EFI fuel line adapters.
Old Mar 28, 2011 | 07:56 AM
travis401's Avatar
Car: 91 Camaro RS
Sweet, thats all I needed.
Old Mar 28, 2011 | 10:24 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
here they are: https://www.thirdgen.org/forums/memb...y-start-3.html
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
knight72
Aug 10, 2015 09:32 PM
