heater box
Old Mar 28, 2011 | 12:19 PM
dustinxix's Avatar
Car: 1988 firebird formula
Engine: 5.7 TPI :)
Transmission: Auto :(
Axle/Gears: 9 bolt LSD
heater box
that plastic black heater box, the one that goes over the heater core location, is it necessary to have? because im in the middle of a headgasket job, my ratchet slipped and i accidently punched a hole in it. do i need it or can i just remove completely?thanks for the info guys!
Old Mar 28, 2011 | 12:25 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: heater box
Won't have any heat if you permanently remove it, or defrost, or any heater control functions - the blower motor is in there. You'll also need to cover that big hole to keep critters out.
Old Mar 28, 2011 | 12:29 PM
dustinxix's Avatar
Engine: 5.7 TPI :)
Re: heater box
thanks for the response!! i see theres an a/c component in front of it which makes removal or replacement diffuclt, is there a trick to it?
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
