Fluttering lights.
Old Mar 28, 2011 | 10:41 PM
shitgoboom21's Avatar
Car: 1987 Camaro IROC-Z
Engine: TPI 305
Fluttering lights.
I have a 1987 Camaro with a TPI 305. I am having some problems with the lighting in the car, well not just inside but pretty much every light bulb on the car. Headlights, dash lighting, dome light. Occasionally while the car is running at idle or driving all the lights seem to flutter or flicker. Its not in a random order or anything they all do it at the same time together. The only other problem is with the dash lighting. One day all the lights function just like they should and the next they don't. Mainly the blinker lights. They come on when I signal and then a few times later they don't. I just figured its a bad ground or bad altenator or something but I have had the altenator tested twice and its good. the battery is good as well. All the grounds I can see are good too. Does anyone have any idea what is going on?
Old Mar 29, 2011 | 10:03 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Fluttering lights.
I was going to say alternator - mine was doing this and turned out that my alternator was overcharging, but you said you had it tested.
Old Mar 29, 2011 | 12:35 PM
Engine: TPI 305
I had it tested but I still think its bad, or at least going bad. Can they test good if they are just starting to fail?
Eric-86sc
Exterior Parts for Sale
Nov 16, 2015 10:20 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
383cam
Sep 9, 2015 06:01 AM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
db057
Aug 22, 2015 08:17 PM
