dizzy 180 dgrees out right?
Old Mar 31, 2011 | 05:07 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
well had no start issue. so went back to timing .i loosened no.1 plug turnt it over by hand. when i started hear air i lined mark up at 0 and rotor button was facing exactly the opposite direction. i hope i am right dont want to mess with it until i hear from guys that know. when i tried to start it like it was. no start and only heard low audible pop.
Old Mar 31, 2011 | 07:44 AM
NY87Iroc's Avatar
Car: 1987 Iroc convertible
Axle/Gears: 3.42 posi
Re: dizzy 180 dgrees out right?
if its on compression stroke on number one cylinder and your timing pointer is on zero, your rotor should be on number one spark plug wire.
Old Mar 31, 2011 | 08:34 AM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
If youre turning it over by hand, take out #1 plug, stick your finger in the plug hole, and turn the engine over untill you feel air trying to push your finger out of the hole. Then line up the timing mark on the balancer with 0, and point the dizzy rotor to the #1 plug on the cap. From there you can stick a timing light on it and set your timing where you want it.
Bubbajones_ya
Jul 6, 2024 08:32 PM
school boy
Oct 22, 2015 11:47 AM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
Dragonsys
Sep 25, 2015 03:51 PM
