whats the diff between 305 and the 305 HO in the 84 motors
Old Apr 1, 2011 | 09:00 PM
ryanguyton's Avatar
i have a 84 camaro with a 305 in her i wanted to know what is the diff between the 305 and the 305 high output i now the high output has more HP but how much more compare to my 305?? can i make my 305 faster? how much more faster what type of heads, cams or other stuff i need to do any brand i should look for thanks! i asking cause i plan or rebuilt my 305 soon and mite as well do some mods while iam doing it
Old Apr 1, 2011 | 11:51 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
There is a thread on that very topic on the FAQ forum.
Old Apr 2, 2011 | 12:00 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: whats the diff between 305 and the 305 HO in the 84 motors
the main internal differences are the "H.O." L69 version
had 1 point higher compression(9.5 vs 8.5)and a
hotter cam.There were a lot of external differences too;
-dual inlet air cleaner
-corvette catalytic converter
-larger passage exhaust manifolds
-bigger exhaust system
-electronic spark control
-deep groove alternator and A/C pulleys
-electric fan
-some later ones had electric low pressure"boost"
fuel pump
IF you have the standard 150HP LG4 305,upgrading the
camshaft and exhaust will give a major power increase
-sure woke mine up back in the day
The L69"H.O. 305 was rated at 190hp,200hp when
premium gas used(some testers reconed the output
was closer to 220hp judging by the performance#s)
Old Apr 2, 2011 | 06:31 AM
ryanguyton's Avatar
o wow sweet any more ideas? so far i need a cam what kind and how big same with the headers
Old Apr 2, 2011 | 08:18 AM
luvmy64's Avatar
IMHO, the only way to get more power from a 305 is to chunk it and replace it with a 350. Im sure MANY others will concur.....
Old Apr 2, 2011 | 09:44 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
to wake up my '82 LG4,i installed headers-cheap
cyclones,and a 3"super single exhaust with custom y
pipe and no converter.The cam i used was sold by
weiand and had specs slightly hotter than stock L69
specs.Rejetted the carb to compensate for the greatly
increased breating capacity.Other modifications included
making functional air induction hood and adding an
electric fuel pump as the original mechanical one would
not keep up at over 5000 rpm for some reason.
I recon modified 305 was putting out around 220-230
hp and z28 was far faster than with engine in original
configuration
this was all back in 1991-94,swapped in a corvette 350
in 1994(still have the original 305 preserved)
No replacement for displacement,but the 305 is a
small block chevy so all the usuall "hot-rod"tricks work
Old Apr 2, 2011 | 10:03 PM
ryanguyton's Avatar
alright thanks for the info
jhawkeye
May 25, 2022 06:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
draco
Oct 4, 2015 09:25 PM
E Rod
Aug 28, 2015 05:17 AM
st.evel07
Aug 13, 2015 06:15 PM
