fuel pressure regulator
Old Apr 2, 2011 | 01:15 AM
james.gould150's Avatar
Car: 1991 z28
Engine: 305 tpi
Transmission: 700r Automatic
how hard is it to add an adjustable regulator/is it worth it to intsall one on a stock 305 tpi?
Old Apr 3, 2011 | 11:29 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: fuel pressure regulator
the best and easiest one to use IMO is the holley. No wrenches to fool with, it has a hand turnable dial.
Old Apr 3, 2011 | 11:36 PM
ninetyone's Avatar
Axle/Gears: 3:42
Not hard to install. You have to take the upper runner bolts off and just loosen a few of the bottom runner bolts on each side. To remove the fuel pressure regulator you will need a special torx bit, called a security torx bit. I am not sure of the size. Just remember to relieve all of your fuel pressure first via the shrader valve. All of your gaskets for the throttle body and runners can be reused, just clean them up. You don't even have to completely remove the throttle body either , just take out the 4 bolts on the front and move the whole unit to the side. Later
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
