Air Intake Snorkel TPI 87 305
Old Apr 5, 2011 | 10:05 PM
Iroc 87's Avatar
Car: 1987 IROC Z28 Camaro
Transmission: Stock
Axle/Gears: Stock
1987 Camaro Iroc z 305 TPI
What is the name of the sensor on the air intake snorkel?(Drivers side)
What does it do?
Also does anyone know if there are two rubber gaskets for the Mass Air Flow sensor one for each end, I only have one, my mechanic said i'm missing the first one from the snorkel to the MAF? this part connects to both ends of the mass air flow sensor coming from the air snorkel to the MAF should be one, then from the MAF to the throttle body should be the second?
Old Apr 6, 2011 | 10:31 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Air Intake Snorkel TPI 87 305
What does it do?
Sounds like the intake was replaced with one from a V6 car. They have the IAT sensor on the drivers side right above the radiator. On TPI cars there is a MAT sensor in the plenum.
Although, a previous owner may have wired the MAT sensor wires to the IAT sensor on the intake. This is known as a relocated MAT.
IAT is intake air temperature, MAT is manifold air temperature.
RBob.
1992 Trans Am
May 10, 2023 07:19 PM
Fast355
Dec 2, 2016 06:33 PM
Jake_92RS
Aug 11, 2015 10:39 AM
bryan623
Aug 10, 2015 11:33 AM
