Oil Pressure and Check Engine Light
Old Apr 6, 2011 | 11:20 PM
Firebird Fly's Avatar
Car: 88 Formula Firebird, 86 Firebird
Engine: 305 TBI and crate 350
My 88 305 TBI has some issues:
First my oil pressure is erratic. It will be fine driving it for half an hour to a whole day then it will gradually fall to just above the red. ive pulled over checked the oil level and everything and the pressuer will go back up and drop again later I keep the oil filled and it has small oil leak.
check engine light. could be because of the oil pressure but the light dosnt always come on when the oil pressure drops. It will come on randomly driving stay on for any where from 5 min to half an hour and when i borrowed a computer and plugged it in (did this 3 times and forgot to write down what it said....i know dumb) it said somethin about the air intake
jus wondering if anyone had any ideas before i spend the money to take it to a mechanic
Old Apr 6, 2011 | 11:42 PM
BillyTheGoat's Avatar
Car: 1989 Trans am
Re: Oil Pressure and Check Engine Light
have you done a pressure test? disconnect the the wire to the oil pressure sending unit and see if it has oil, it should be dry
Old Apr 7, 2011 | 09:49 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The oil pressure isn't erratic, the sender is. Just replace it.
The check engine light is a different issue that has nothing to do with the oil pressure sender.
Old Apr 7, 2011 | 11:31 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
On the engine light .... Pull the codes for your check engine light!
Grab a paperclip and read: https://www.thirdgen.org/service-eng...ht-error-codes
On the oil pressure, try a new sender like mentioned. It's located above oil filter, about $30.
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
