est wire 85 L69 4bbl ?
Old Apr 8, 2011 | 01:31 PM
mrcurl's Avatar
Car: 1985 silver iroc
Engine: L69
Transmission: manual
Im starting to think im chasing a ghost. Does the 85 iroc L69 have an est wire because i cant find it.im uploading photos now of the dist and the carb to help,its just taking a bit.
Old Apr 8, 2011 | 01:35 PM
mrcurl's Avatar
Engine: L69
Re: est wire 85 L69 4bbl ?
my pics are too big to upload. will take some more.
Old Apr 8, 2011 | 02:44 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Yes - it does.
Follow the large wire loom from the pass side fender at the firewall - somewhere in that loom, usually close to the strut tower on pass side, the loom will open, have a single tan wire that comes out with a connector on it, and it goes right back into the same wiring loom. The connector is usually black, about the size of an ink pen round, and about 2 inches long.
Old Apr 8, 2011 | 03:42 PM
mrcurl's Avatar
Engine: L69
i have opened all wire looms and did not find a tan and black. i have some pics of what it looks like
Old Apr 8, 2011 | 03:44 PM
mrcurl's Avatar
Engine: L69
more
Old Apr 8, 2011 | 03:47 PM
mrcurl's Avatar
Engine: L69
i have opened all looms and did not find a tan and black let alone any conector. Is it possible it is a different color ? does anyone know where this wire originates from ? or where it terminates ?
Old Apr 8, 2011 | 04:57 PM
Car: 1992 RS
Engine: Carbed 350
.Hmmm. What about farther up front - like around the strut tower - there should be a loom there - has wires for the alternator, the starter, and the fusible links, as well as the knock sensor wire.
Draw a mental line, from the front of the water pump to the pass side fender. Then, halfway between that line, and the A/C evaporator - down beside the side of the strut tower - what's down there? Should be another loom in that area - that's where I've always found the EST wire.
Old Apr 8, 2011 | 05:00 PM
Car: 1992 RS
Engine: Carbed 350
here's a pic of the area I always found them in - inside the red circle somewhere:
Old Apr 8, 2011 | 05:02 PM
mrcurl's Avatar
Engine: L69
i opened this one and no luck
Old Apr 8, 2011 | 05:05 PM
Car: 1992 RS
Engine: Carbed 350
I'm lost - you shouldn't have to open any loom - it should just be hanging out on it's own! If the car is computer controlled, it has to have an EST wire. And I see no vacuum advance can on your distributor, so I'm assuming it's computer controlled. You do have things on the carb right? Like a TPS, IAC, etc. - it's a computer controlled carb right?
Old Apr 8, 2011 | 05:30 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
From '82 to '86, the EST connection was a flat 4-wire connector in the wires coming from the base of the distributor going into the loom that goes across the firewall. You don't have to unwrap the loom, but the connector often hides behind & below the distributor.
Old Apr 8, 2011 | 05:32 PM
mrcurl's Avatar
Engine: L69
thats one thing i am unfamiliar with. it has 2 separate wire connectors so i assume it is.
Old Apr 8, 2011 | 05:36 PM
mrcurl's Avatar
Engine: L69
I know the 4 wire connector, but the loom i open that that is in has no tan / black wire ( that i can see ). does this wire enter the firewall on the passengers side next to the fan ?
Old Apr 8, 2011 | 07:46 PM
Car: 1992 RS
Engine: Carbed 350
OK - that makes sense.
Old Apr 8, 2011 | 07:49 PM
mrcurl's Avatar
Engine: L69
are you saying i can stop looking for the tan wire, or are you saying that if i follow the 4 wire connector it will lead me to the tan and black ?
Old Apr 9, 2011 | 09:15 PM
five7kid's Avatar
I'm saying stop looking for "a" tan & black wire, or "an" EST wire. On the '82-'86 V8 models, you disconnect the flat 4-wire connector to set the base timing.
Or, were you trying to do something else with the EST wire?
Old Apr 9, 2011 | 09:18 PM
five7kid's Avatar
Attachment 217214
Attachment 217215
That is a computer carb. The connector on top is the mixture control solenoid, and the one on the front is the throttle position sensor.
Old Apr 10, 2011 | 08:14 AM
mrcurl's Avatar
Engine: L69
Thanks for the clearification. I thought i was going insane.
Chuck84TA
Jul 15, 2016 09:05 PM
1992Vortec
Aug 31, 2015 08:05 PM
Bryan F
Aug 27, 2015 07:28 AM
86IROC112
Aug 17, 2015 02:00 PM
Dquickshift
Aug 12, 2015 06:21 PM
