low mount alternator
Old Apr 11, 2011 | 07:18 AM
camaroboy199290's Avatar
Car: 89 iroc
Engine: 355tpi
Transmission: jasper 700r4
Axle/Gears: 4.11 lsd
i have a 92 rs and im putting in a 383 and i want to put a low mount alternator on the car but im not sure if it will fit because of the steering components being so close has anyone else had any sucess with using one of these alternator mounts
Old Apr 11, 2011 | 10:41 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: low mount alternator
I'm assuming your getting rid of the serp bracket system? If so, why not mount the alternator on the pass side (where it should be in my book anyway)?
Know that, if your changing from the factory serpentine bracket system to ANY other system, you'll have to replace ALL the accessories (water pump, p/s pump, A/C, and smog pump). In other words, the mounting holes in the serpentine accessories will not work on any other bracket system EXCEPT the factory serpentine system.
Alternator - serp has holes at 12 and 8, non-serp has holes at 12 and 6
water pump - serp system uses a reverse rotation water pump, all others use standard rotation
p/s pump - again - the mounting holes are located differently, a serp p/s pump won't connect to a non-serp bracket
A/C - completely diferent - serp setup has small A/C compressor on pass side that is short to accomodate valve cover, nonserp has compressor on driver side that is a longer old-style unit.
Old Apr 11, 2011 | 02:21 PM
Car: 89 iroc
Engine: 355tpi
the only thing im running is a alternator off the crank i have a electric water pump manual steering box no ac smog and the alternator is gonna b on the side thats ill fit on if it cant go on the driver side
Old Apr 11, 2011 | 03:11 PM
Car: 1992 RS
Engine: Carbed 350
You'll need a pre 1988 alternator for anything other than a factory serp bracket - you need an alternator with mounting holes at 12 and 6 oclock - then you can use any bracket you like for it.
Old Apr 11, 2011 | 07:10 PM
Car: 89 iroc
Engine: 355tpi
i just got a bracket from a friend to try to mock up and on the passenger side it hits the idler arm and on the driver side it hits the pitman arm
Cleotiz
Aug 23, 2015 12:07 PM
g.l.mos
Aug 22, 2015 12:02 AM
guy76767
Aug 6, 2015 05:58 PM
NBrehm
Aug 5, 2015 07:57 PM
