WOT Issues
Car: '91 Firebird '85 Firebird
WOT Issues
So i have a 1991 with the 305 tbi. When the car is idleing and you WOT the engine immediatly bogs down(read: does not gain rpms at all) and will stay bogged for about 2-5 seconds and then it will start gaining rpm's. If i bring the engine to 1.5k-2k rpms and then WOT it shoots up just fine. At first i thought fuel pump/filter. The pump seems to be working fine, and i replaced the filter. When that didnt fix it i changed the spark plugs and wires, still no fix. Anything you guys can think of will help me greatly, 2moro im getting a code reader to see what code its throwing. A friend suggested possible TPS/ MAP sensor issues. Your thoughts?
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: WOT Issues
Don't need a code reader - you have one! Grab a paperclip and read: https://www.thirdgen.org/service-eng...ht-error-codes
Did you change rotor and dist cap also? Plugs and wires no good without new cap and rotor.
