86 iroc won't start
Old Apr 18, 2011 | 11:34 AM
jw86iroc's Avatar
86 iroc won't start
Hi everybody, I'm looking for help with this problem child. The car is a 86 iroc automatic, 305 tpi, 67k miles all stock, no mods. The car was running ok but was due for a tune up. I started with plugs, wires, dist. cap,rotor, and icm. I tried to start it and it would turn over but not start. I double checked connections and firing order. That was all fine but still no start. I put a gauge on the fuel rail and turned it over, the psi went up to 40. Spark seems to be ok. When I tried to get the trouble codes by jumping the aldl and turn on the key the fan comes on and the relays by the brake booster make odd sounds?
Any help would be appreciated. Thanks
Old Apr 25, 2011 | 04:54 PM
jw86iroc's Avatar
Re: 86 iroc won't start
Anybody??
Old Apr 25, 2011 | 05:29 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
The clicking relays and fan on are normal in diagnostic mode. It ran before you did the tune up. Check your work. I think you're missing something. For one thing, check the four pin connector to the ICM. Are the pins of the ICM bent? About 1/2 of the cheap aftermarket replacement ICMs I've seen have had one or more bent pins.
Derick15
Sep 17, 2016 05:28 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
mustangman65_79
Aug 11, 2015 03:17 PM
