1995 Trans Am Lt1 383 distributor burning out
Old Apr 19, 2011 | 08:47 AM
Guest
Guest
Posts: n/a
I have a Lt1 383 that is new and keeps burning out the sensor in the distributor. I have replaced the stock distributor with a MSD Opti-Spark vented distributor and it melted the sensor in it as well. I have had the computer reflashed for the specs of the new upgrades and that was not the problem. Each time that I replaced the distributor it would only run for 2 weeks at a time and then suddenly just quit. I now have 2 distributors and 2 computers that I have replaced with and don't know where the problem is starting.
Specs of new motor:
LT4 intake
Comp Cam 510
Forged Flat top Piston
30lb Injectors
Ported Heads to match Intake
58MM Throttle Body
Moroso Cold Air Kit
EGR block Off Kit
Emissions Delete
Vats Bypass
Cloyes High Performance Timing Chain
eightsixseven
Dec 16, 2024 01:50 PM
midge54
Jan 29, 2017 07:00 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
