Need help identifying wire
Old Apr 19, 2011 | 09:06 AM
92rsrestorer's Avatar
hey guys, i recently found this wire dangling from the bottom of my 92 305 engine bay. I been having problems with a rough idle here recently on start that smooths out but throws a SeS light on as soon as it smooths out.I used the paper clip method and got a map sensor and fuel pump error codes, replaced the map sensor but want to try all my options before replacing my fuel pump. I checked the fuse, in process of changing the relay and fuel filter.Anyways i was wondering what this strange wire was and whether it could be a cause of some of my problems.
Old Apr 19, 2011 | 09:07 AM
Re: Need help identifying wire
http://img97.imageshack.us/i/photo0016ie.jpg/
Old Apr 19, 2011 | 10:21 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
If your electric fan is working, then it's the knock sensor wire.
Knock sensor is in the block, has a mushroom looking connector on it. It senses spark knock and sends info to computerized distributor to retard/advance timing to get rid of knocking. Here's a pic of what the knock sensor looks like: http://tpiparts.net/inc/sdetail/10956/428
You can order another connector end at just about any auto parts store - ask to order a Dorman part number 85140. Or you can order it here: http://tpiparts.net/inc/sdetail/10962/3658
Dealer would also be able to get, but cost is going to be higher at dealer, and they won't have it in stock either.
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Redwhisper
Aug 26, 2015 05:02 PM
Linson
Aug 21, 2015 02:12 PM
Street Lethal
Aug 14, 2015 08:25 PM
