My engine.. what is it?
Old Apr 19, 2011 | 04:33 PM
HacksawHannibal's Avatar
Car: 1988 Camaro
Engine: V8 (Carb)
I just brought my third gen and i have not clue what engine is in it. I do know that its a Edelbrock (which is pretty obvious) and the its a 350 small block. Can someone tell exactly what it is and what it needs?
Attached Thumbnails My engine.. what is it?-future-car-2.jpg   My engine.. what is it?-img00210-20110419-1720.jpg   My engine.. what is it?-img00212-20110419-1720.jpg
Old Apr 19, 2011 | 04:35 PM
88 5.7 Iroc-Z's Avatar
Car: 88 Iroc Z, 00 SS
Engine: 5.7 HSR, 5.7 LS1
Transmission: 700r4, T56
Axle/Gears: 3.23, 3.42
Re: My engine.. what is it?
no, ur carb and possibly intake are edelbrock, look at the back of the engine for casting number to give you an idea of what you have
Old Apr 19, 2011 | 04:43 PM
Car: 1988 Camaro
Engine: V8 (Carb)
So tht cage looking thing ..what is tht.. the carb?
Old Apr 19, 2011 | 05:18 PM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
i think your talking about the air cleaner... that sits on top of your carb.
the carb is an edelbrock, it is the object that is badged edelbrock
what it NEEDS is for you to keep your hands off of it untill you do some reading about chevy small blocks and third gen camaros in general.
Old Apr 19, 2011 | 05:21 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
The "cage" looking thing is the air cleaner, and needs removed ASAP. We call those the "Triangle of Death" - the foam will melt if you ever backfire, and burning melting foam will get sucked into the engine and make a mess.
Driver side, rear of block, under the head - there will be block numbers - you need to get those to tell whether it's a 283, 302, 305, 307, 327, or 350 - because externally you can't tell the difference between any small blck chevy. The numbers are very hard to find - no room for your head to get in there and see - try using a compact mirror.
Old Apr 26, 2011 | 02:40 PM
Car: 1988 Camaro
Engine: V8 (Carb)
Thanks for the help
yager
Oct 4, 2005 08:10 AM
vorgath
Aug 26, 2005 03:07 PM
DreamState21x
Jun 2, 2003 10:04 PM
ShaneBuss2
Sep 23, 2002 07:27 AM
JeffC1500TBI
Feb 28, 2002 05:06 PM
