Trying to figure out where this vacuum hose goes
Car: 1985 IROC-Z
Transmission: T5 manual
earlier today i was replacing my wiper motor and when i pulled out the old motor this hose was just laying underneath, when you start the car it starts to suck air, i know a couple weeks ago my father in law said he could hear something like i had a vacuum leak or something and im thinking this might be it but i don't know where its supposed to go back on at. thanks for any help on this.
Car: 1985 IROC-Z
Re: Trying to figure out where this vacuum hose goes
just in case you cant tell from the 2nd pic its the one thats running toward the engine away from the camera
Car: 84 trans am
Engine: 305 5.0L HO
Transmission: TH350
If I'm not mistaken that is manifold vacuum.
On my motor that went to the transmission. TH350.
There are other applications that use it also.
I don't know your setup.
Sucking air from there is a serious effect on performance.
Car: 1985 IROC-Z
my setup is just the stock 305 with a stock 4 bbl car its all stock. i just bought this car last month.
If it's "sucking air", then it doesn't need to go to manifold vacuum; it already has it.
It's impossble to tell anything at all from the pics. They're blurry and have no contrast. Plus, the motor is obviously filthy; desperately needs a trip to the quarter car wash. Just CLEANING IT UP might make it a whole lot easier to figure out what you're looking at.
What's at the other end of it? It's like wires; what's at one end, is often a handy clue as to what belongs at the other.
Car: 1985 IROC-Z
sorry about the state its in like i said i just got it and havent had a chance to really clean it up
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
First thing to do is to get a chiltons repair manual at a local auto parts store, they have the vacuum diagrams in there. You'll need it for other things anyway.
Ultimately, that vacuum line supplies vacuum to the HVAC vacuum servos under the dash to change from floor to vents to defrost.
In 87 I can't remember where the vacuum reservoir is, though, unfortunately. It's either....
1. A straight shot to the "mini-mailbox" shaped vacuum reservoir above the power brake booster or
2. It goes to a T fitting off which one side goes to the round vacuum reservoir inside the front of the driver's fender and the other side of the T goes into the main wiring loom and up under the dash.
First type is older, second setup is later models. Can't remember where the cut-off year was, but I think 87 is the later setup.
86CamaroDan
Sep 29, 2015 10:08 PM
