msd digital 6 high rpm misfire
Old Apr 22, 2011 | 08:58 AM
dellman83Z's Avatar
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
Has anyone ever had an issue with his box. At first, I replaced pretty much everything ignition related to get rid of the misfire after 4000 and under load. I finally swapped back in my old box (6al-2) and the problem disappeared immediately without changing any of the wiring with the exception of the wire to retard the timing when the nitrous is activiated. Just wondering if there is something that could be causing interference with the box causing the issue and maybe other things that could cause it.
mdtoren
Aug 23, 2015 12:52 PM
overdriv
Aug 20, 2015 03:52 PM
mdtoren
Aug 16, 2015 05:45 PM
tartagliaz28
Aug 15, 2015 10:59 AM
