tools need for ud pulley install
Car: 1989 formula
Engine: 350 l98
Transmission: 700R-4
Axle/Gears: 327
what tools are needed for installing march ud pulleys from what i can see looks like some sort of torx any body have the size or will the bol on the alternator be the only thing to loosen and were is the water pump very new please don't flame thanks it is the 3 pirsce power and amp set also does anyone know what size belt i will have to use just trying to make sure i am prepared when they show up on tues i think the number on the belt now is 6-95-35 or 35-95-6
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: tools need for ud pulley install
My March set had water pump, alt, and crank. Alternator was the most difficult I put on gloves held the pulley and hit the pulley bolt with the impact wrench came off fairly easy. I can't recall for the OEM Balancer but my new ARP bolt does not fit in the center of the March Crank Pulley, so it takes a large breaker bar to break it loose and a torque wrench to tighten it again. If you do have to remove the harmonic balancer bolt make sure to get it tight again bad bad things happen if one walks loose off the snout. Water pump is easy it's just 4 bolts (maybe nuts if you're using a stud kit).
Alternator is normally around 1 o'clock position on top side, Power Steering 4 o'clock position, AC (if you have it) 10 o'clock, Smog pump 8 o'clock, Crankshaft (harmonic balancer) 6 o'clock, and the water pump is basically dead center.
Tools:
Sockets (may torx too I can't recall)
Ratchet
Breakbar
Torque Wrench (for the balancer bolt if you remove it)
I ran the alternator pulley for awhile but developed power issues so I went with a smaller pulley off eBay. The nice polished one is in my toolbox still.
Tools:
Ratchet
Breakbar
Car: 1989 formula
Engine: 350 l98
Axle/Gears: 327
ok thanks i ordered the power and amp set so hopefully that will solve the charging issus thanks for the info how do you know if you ned to pull the harmonic balancer bolt
Engine: 383 SBC
Crankshaft pulley is connected to the balancer. There is a few bolts (3 I think) spaced out around it. There is one massive bolt in the center. If you have to remove the center bolt (balancer bolt) to get the pulley off and install the new one that's how you know. The balancer bolt holds the balancer against the crankshaft to keep it from walking.
Found you a thread about the crankshaft pulley. Yes it looks like you're need to remove the balancer bolt also. https://www.thirdgen.org/forums/tech...ft-pulley.html
Just be careful with the balancer bolt. That's not something you want to strip out. When you go to install the bolts again make sure you start all bolts by hand for a few turns to make sure they are not misthreaded before using a ratchet on them.
Car: 1989 formula
Engine: 350 l98
Axle/Gears: 327
ok thanks is there any other way to keep the engine from spinning
Engine: 383 SBC
I've never had to hold the engine when taking out the bolt.
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
Navy8125
Aug 22, 2015 07:13 PM
