got it done
Old Apr 23, 2011 | 11:57 PM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
got it done
just finished replacing my motor mounts without removing the engine, and WITHOUT removing ANY part of the suspension. nor did i drill cut or weld on anything.
this may seem insignificant, but its been something ive been sweating and putting off all winter long. and whenever i posted or read anything about, i was told to remove the a-arms and springs. (which seems pretty tuff if your not set up to do that, like im not)
just another example that the right tool makes all the difference. i needed:
- a 15mm universal socket (the most important thing that made this possible, thanx be to ASE doc for that piece of advice)
-14 inches of 3/8 socket extention
-a chunk of 2x4
-2 sets of hands turning wrenchs
-3 sets of patience
the only concerns i have are that i replaced the mounts with more rubber ones instead of poly or solids ( at least i know how to do this now if they rip loose again)
and i use a 12in chunk of 2x4 to wedge between the oil pan and the sub-frame (the pan looks fine, but ill have to wait and see i guess...)
anyway, its on to the next thing that breaks. theres always something...
Old Apr 24, 2011 | 08:41 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: got it done
Thanks for posting. It's always nice to get helpful tips like this.
Old Apr 26, 2011 | 07:30 AM
torque_is_good's Avatar
Re: got it done
ase doc is a wise man
