Edelbrock air cleaner 305 tbi?
Old Apr 24, 2011 | 03:33 PM
dukie's Avatar
Hey guys, I was thinking of adding an aftermarket air cleaner to my 88 camaro convertable.
It has a 305 tbi engine.
Would adding one like this work?
http://www.summitracing.com/parts/EDL-1223/?rtype=10
I like the look and just want to make sure it won't throw codes if I go with it.
Thanks in advance.
Old Apr 24, 2011 | 03:41 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Edelbrock air cleaner 305 tbi?
Yes - but you may need a 1/2 spacer between TBI unit and carb so that the base clears the linkage. Might also have to use a 2in filter instead of a 3in filter to get hood clearance. That's why I never buy sets - they always come with something I can't use yet I have to pay for. Can you get the base and lid without the filter?
You'll also need a straight piece of 1/4-20 threaded rod (stock TBI rod is bent), and you need to make sure you connect the IAT sensor in the base, and make sure you cap off the vacuum line to the heat riser door flap.
Old Apr 24, 2011 | 03:45 PM
dukie's Avatar
WOW. thanks for the quick reply.. I will go with the low one and get the spacer for good measure.
Basically, it won't throw codes though right?
Also, will it add to the performance of the car? I really just want Mental horsepower anyway.
Old Apr 24, 2011 | 03:58 PM
Car: 1992 RS
Engine: Carbed 350
Won't add anything that you'll notice, and no it won't throw any codes as long as that IAT sensor is put in the new base (or mounted close to the base). Look for a metal 1/2" spacer - I had Mr. Gasket plastic crapola and the heat breaks them the first week.
Old Mar 29, 2012 | 08:09 AM
gabes92rs's Avatar
Car: 92 camaro rs convertible
Engine: 305, L03
im thinking of doing the same thing to my 92, it also has a 305 tbi and i wanted to put an after market air cleaner like that, since its been almost a year now how were you able to get it on did you just have to get the spacer and the new rod?
Old Jul 17, 2012 | 07:56 PM
dukie's Avatar
Sorry Gabe,
I haven't been on in a long while.. Short answer. No I did not buy it.
But I am thinking of some other options for a wee bit of power.
Probablly a cam and headers. Just need to get out and do it.
I only drive the car a couple of times a year, but you know.
86IROC112
Sep 7, 2015 01:37 PM
86IROC112
Aug 17, 2015 02:00 PM
wruiz
Aug 13, 2015 09:07 PM
92purpz28
Aug 11, 2015 02:30 PM
