blue smoke
Old Apr 24, 2011 | 10:30 PM
88ragtop's Avatar
Car: 88 sport coupe convert
Engine: 305 tb
Transmission: auto
blue smoke
88 305 does not smoke on first start up but if you are stopped at a red light for a while about 10 minutes after the startup the car leaves a big puff of blue smoke. Does not seem to smoke if I never stop. I thought maybe valve seats but I would think it would smoke at initial start up. Car has only 60,000 miles. What to look for?
Old Apr 24, 2011 | 10:59 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: blue smoke
Probably worn valve seals - nothing to worry about
Old Apr 24, 2011 | 11:31 PM
dirtywhiteZ28's Avatar
Car: 84' Z28-White/T-Tops
Engine: H code LG4 305
Transmission: TH700R4
Axle/Gears: Stock 3.23
Re: blue smoke
My '91 vert started doing that after the fan went out and it over heated. The shop said that the temp sensor for the computer was fried and the thermostat was stuck open. They said the smoke was from the computer thinking that the motor was still cold and trying to compensate by running rich.
Old Apr 24, 2011 | 11:33 PM
90 camaro cj's Avatar
Car: 1990 camaro RS
Engine: 305 TBI
Re: blue smoke
blue smoke is oil, black smoke is rich, white is water (in air or leaking in) so its not running rich, i go with what camaronewbie said, no biggie unless it wont pass emessions, just keep the oil full
Old Apr 25, 2011 | 08:55 AM
boot legger's Avatar
Car: 1985 Trans Am
Transmission: A4
Re: blue smoke
ya its probly just need valve stem seals replaced
Old Apr 25, 2011 | 10:32 AM
mswen22780's Avatar
Car: 1985 Chevrolet Camaro Z28
Re: blue smoke
Doing valve seals isn't too bad, especially if you don't mind doing spark plugs. The seals can be changed without removing the heads. Use an air line adapter and thread into spark plug hole, the air pressure will keep the valve up while you remove the locks and springs. Remove old seals and isntall new.
Linson
Oct 24, 2025 02:00 PM
FormulasOnly
Jul 23, 2018 08:47 AM
Lbibb
May 5, 2016 12:00 AM
gord327
Oct 3, 2015 01:25 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
