How do you start your engine while its still on the stand?
Old Apr 26, 2011 | 05:53 PM
30reddogs's Avatar
Car: 1987 Camaro
Engine: 350 5.7 TPI
My engine rebuild is almost complete and I am almost at the point where I can start my engine. I would like to start it before putting it in the car...I have never done this before.
I was wondering:
what types of checks i will need to do before starting it?
What exactly do i need to do?
are there any either youtube or a video link that shows you how to do this?
and anything else anyone can think of....
Im all ears.
Old Apr 26, 2011 | 05:59 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: How do you start your engine while its still on the stand?
You need to buy, borrow or build a break-in stand.
Old Apr 26, 2011 | 06:02 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
What kind of engine? Carb only or computer? Make sure it's got oil. Then it depends on if you just want to fire it up for a few secs or keep it running. If it's a carb you can pour some gas into the carb and it should fire. If you want to keep it running you'd need a cooling system hooked up to it and a small gas supply to the carb. If it's fuel injected and/or computer controlled just think of everything it would have connected to it in the car and replicate it somehow. Could be a big job but sounds interesting. Anyone know if there's a ready made way to connect a computer etc.?
Old Apr 27, 2011 | 11:08 AM
StrahlZ28's Avatar
Car: 1991 Z/28
Without a run stand it's not a good idea to do this.
The best thing you can do is prime the oiling system to make sure you have oil in the right places. Pull the valve covers off and remove the distributor. Go get yourself a priming rod for a sbc (Or make one out of a long shank flatblade screwdriver, I did this for quite a while and it worked fine until I lost it ) put it in a cordless drill and spin the oil pump shaft. If you have everything good to go oil should come up to the heads in a minute / minute and a half.
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
TheExaminer
Aug 26, 2015 04:59 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
