Spark plug diagnosis [Pic]
Old Apr 27, 2011 | 09:11 PM
Krishan's Avatar
Car: 1991 Z28 Camaro
Engine: 5.0 305 TPI
Transmission: 4-spd Auto
First time replacing all 8...regardless of the current conditions of the plugs.
[/URL]
I'm seeing some matte brown on some plugs, I read up that it could be "dry fouling"
Any experienced spark plug replacers, any judgement/ comments on the plugs?
Got this 91 Camaro practically as a hand-me-down. so I have no idea what this car has been through for the past 20 years.
Any help will be appreciated.
Old Apr 28, 2011 | 12:36 AM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Re: Spark plug diagnosis [Pic]
[/url]
Hello Krishan!!
Your plugs look fine!!
Clean them, or for the cost, replace them!!!
Old Apr 28, 2011 | 11:42 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Chocolate milk! Yummy! Also, means proper combustion when on a spark plug.
Old Apr 28, 2011 | 11:50 AM
StrahlZ28's Avatar
Car: 1991 Z/28
I'd replace, it looks like some combustion gases were escaping between the steel and porcelain. Or it's dirt build up, hard to tell.
Old Apr 28, 2011 | 12:14 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
When replacing plugs, carefully inspect secondary ignition components. Wires, cap and rotor wear out at about the same rate as the plugs. Wires may appear okay but if you check more cosely you amy find that they are more stiff than when new, that the boots are less supple. The cap and rotor will likely have powdery deposits from arching of the high voltage passing through them. Where the center cap "button" contacts the center of the rotor, you will find black powdery deposits. To assure best results with your tune up, replace all of these parts together. Also, coat the inner surface of the plug boots liberally with dielectric grease to seal out oxygen and prevent electrolysis.
Old Apr 28, 2011 | 07:17 PM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
and so you can get the boots off later if you ever gotta take them off again.
Old Apr 28, 2011 | 08:28 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Spark plugs are cheap. Replace them every 2 years even if they don't look like they need replacing.
evilstuie
Feb 28, 2016 03:33 PM
LittleFranks
Sep 17, 2015 12:22 PM
tricky1
Aug 23, 2015 01:17 PM
g.l.mos
Aug 22, 2015 12:02 AM
