Bolt under pitman arm
Old May 1, 2011 | 10:00 AM
native1031's Avatar
Does it come off first, before I use the pitman arm removal tool?
Old May 1, 2011 | 10:06 AM
Damon's Avatar
Re: Bolt under pitman arm
Yes. Not that a pitman arm would EVER fall off without it (you'll see what I mean when you use the tool) but yeah, you gotta take it off.
Old May 1, 2011 | 10:11 AM
native1031's Avatar
Do you know the size? I dont have a wrench that big
Old May 1, 2011 | 10:14 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
You may want to hit those splines with some penetrating oil a few days before removal.
Old May 1, 2011 | 10:24 AM
native1031's Avatar
What exactly are the splines. I dont know the technical names for everything. Its been hit acouple times over the past hour, and im still trying to get the last tool
Old May 2, 2011 | 03:56 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Just spray the lube all around the part of the pitman arm that connects to the steering box.
New2Chevy
Sep 28, 2015 12:35 AM
billybob6110
Sep 23, 2015 01:30 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
