NO POWER?
Old May 2, 2011 | 04:36 PM
joeyspagz's Avatar
Car: 88 Firebird Trans Am
Engine: 305 tpi
Transmission: 700r4 shift kit
Axle/Gears: Posi
NO POWER?
i just got my 88 trans am 305 tpi running and my idle goes up and down till i hit the brake, so i took it down the street and theres like a half a second bog when i put the pedal to the medal, and the take off is sluggish but after it gets going its fast with power. i changed fuel pump, fuel filter, and oil pressure switch. please help thanks
Old May 2, 2011 | 04:46 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: NO POWER?
Might check the timing - remember to disconnect the EST wire first.
Any codes? Pull codes - that might tell you something. https://www.thirdgen.org/service-eng...ht-error-codes
Old May 2, 2011 | 04:57 PM
joeyspagz's Avatar
Engine: 305 tpi
Axle/Gears: Posi
Re: NO POWER?
yes i have a check engine light on i just cant get a scanner yet
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
