Does this have a purpose?
Old May 2, 2011 | 12:53 AM
'87IROCZOWNER69's Avatar
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
What is the part that I circled in this picture? It's not my car but mine has the same thing and I had a friend who thinks it is supposed to be connected to something.
Old May 2, 2011 | 01:22 AM
bjm1206's Avatar
Re: Does this have a purpose?
i was wondering the same thing i have a 90 iroc and mine has the same connection with nothing connected to it
Old May 2, 2011 | 03:55 AM
Twin_Turbo's Avatar
That's an intake air temp sensor, someone installed it there. Originally it's in the underside of the upper manifold plenum. This location will add more fueling because the ECM sees a colder IAT reading.
Old May 2, 2011 | 08:25 AM
So is there a wire that is supposed to be connected to it somewhere?
Old May 2, 2011 | 08:29 AM
89RESTO's Avatar
2011 Norwood Gathering
ThirdGen Camaro Rep
Car: 1989 IROC
Engine: 5.7
Axle/Gears: 9 bolt 2:77
That looks to be an air intake from a v6 with the mat sensor installed. as Twin_Turbo said, you should have a mat sensor at the rear of the plenum connected to the wireing harness.
Old May 2, 2011 | 08:40 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by 89RESTO
That looks to be an air intake from a v6....
JamesC
Old May 2, 2011 | 08:42 AM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
yep. My V6 has that sensor, but it's actually hooked up to something
Old May 2, 2011 | 09:01 AM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
You can get a special wire harness that extends from the air temp sensor under the plenum to the sensor on your intake. For example;http://tpis.com/parts/view/157
Old May 2, 2011 | 09:11 AM
JamesC's Avatar
Very interesting. Thanks Twin_ and Red.
JamesC
Old May 2, 2011 | 04:10 PM
So is it one from a V6 or is it just part of some kit? Does it make any noticable difference from having it plugged in vs having it unplugged? Pros/cons?
Old May 2, 2011 | 04:16 PM
Twin_Turbo's Avatar
It moves the IAT from the hotter plenum to the cold airbox, adds a little fueling. May add some HP @ WOT. Cheap mod for a little gain.
Old May 2, 2011 | 04:18 PM
I might want to look into finding that plug then and try to plug it in!
Another question, where is the EST located on our cars? Mines throwing a code and Chilton says it will throw a code if unplugged.
Old May 2, 2011 | 04:21 PM
Twin_Turbo's Avatar
Here it is, underside of plenum.
The wire runs near the distributor, 2 pin connector
Old May 2, 2011 | 04:24 PM
Attachment 218630
So is that the EST then? The picture in the Chilton manual is very confusing and doesnt give a reference to where the thing is, just has a picture of a jumble of wiring.
Old May 2, 2011 | 04:26 PM
Twin_Turbo's Avatar
That's the IAT, intake air temp. I didn't read your post properly, thought you were looking for the iat.
The EST is the spark timing box, it's near the brake booster, there are a couple of relays on the firewall and a larger black box w/ a red weatherpack seal and a multi pin connector on the engine side. There's most likely a relay mounted on the front of it. It's a thin black box.
Old May 2, 2011 | 04:30 PM
Ok, so what sort of things will happen if the EST is unplugged (sorry if I seem stupid but Chilton doesnt say what it does either)?
Old May 2, 2011 | 04:31 PM
Twin_Turbo's Avatar
The engine will run like crap, if it runs at all. the EST is the electronic spark timing controller, it controls your timing advance and retard as instructed by the ECM and info from the knock sensor.
This is the EST:
See the 3 relays on the firewall? The inner most one is mounted on a box w a big weatherpack connector on the left side , it's right next to the 2 big wire looms and under the black braided fuel lines.
Old May 2, 2011 | 04:34 PM
If mine is unplugged that would definatly explain why it is running like crap. Thanks for the help everybody. Twin_turbo I will go check on that in a little bit and see what it all looks like.
Old May 2, 2011 | 04:39 PM
Twin_Turbo's Avatar
I added a pic to help you locate it
Old May 2, 2011 | 04:42 PM
What pic?
Old May 2, 2011 | 04:43 PM
Twin_Turbo's Avatar
attached pic in post #17
Old May 2, 2011 | 04:49 PM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Twin_ turbo that's a really nice looking engine bay, and engine!
Old May 2, 2011 | 04:50 PM
Twin_Turbo's Avatar
thanks, I have a lot of time and effort into it.
Oh so the pack that branches off the left side then? I will go look for it then.
Old May 2, 2011 | 04:57 PM
Here's what mine looks like atm...
Right now the weather pack has 4 wires in it and the pack has room for 5?
Attached Thumbnails Does this have a purpose?-plug.jpg   Does this have a purpose?-plug1.jpg   Does this have a purpose?-plug2.jpg
Old May 2, 2011 | 05:49 PM
So I cracked open the black plastic tube that holds the wires and I cant find any wires hiding in it so I am wondering if that top wire is even very important. Is it?
Old May 4, 2011 | 11:48 AM
Twin_Turbo's Avatar
I'll have to check how many are in mine. Don't think there was an empty pinout on the esc
Old May 4, 2011 | 02:58 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Only four of the five connections are used on the ESC module. Also known as the knock filter. With it unplugged the ECM should toss a SES light and code 43. Then pull a set amount of timing which will reduce power and mileage.
The EST control is the ignition control module in the distributor.
On the TPI MAF f-body's the MAT is only used for the EGR turn on temperature threshold.
RBob.
Old May 4, 2011 | 03:36 PM
RBob.
So... that means...?
Old May 4, 2011 | 03:44 PM
Twin_Turbo's Avatar
Oh I see I goofed, I mixed up est and esc, my bad. Yes, the est is inside the ign module.
Old May 4, 2011 | 04:18 PM
So how do I get to that to fix it? Would it have all the same symptoms?
Old May 5, 2011 | 03:15 AM
Twin_Turbo's Avatar
Remove the distributor, pull the cap and rotor and you can unscrew the est. it's the black part where the 2 weatherpack connectors go in the base..
Old May 5, 2011 | 12:14 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
An EST error will set code 42. This will also occur when the EST/BYPASS connector is open, such as when setting the distributor base timing. So if the SES is on and code 42 is active, then make sure that the EST/BYPASS connector is firmly connected. Found over on the passenger side near the A/C box. Single tan with black stripe wire.
If the code 42 is only stored (not active) and the timing has been recently set, then no worries about it. After 50 good start ups the ECM will clear the stored code(s) for you.
RBob.
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
Mongoose462ci
Sep 16, 2015 11:46 PM
lock1983
Brakes
Sep 9, 2015 09:08 PM
