Rebuilt engine seeming to go through a lot of oil
Old May 2, 2011 | 11:53 PM
iroc-z_23's Avatar
Car: 1986 Iroc-z Camaro t-top
Engine: 355 SBC
Transmission: 700r4 TCI const. Pres. Valve body
Axle/Gears: 3.73 posi/mosuer axles
I have a 355 sbc I had rebuilt last year and went to a car show this weekend and checked oil before I left and had 70 psi oil. On my way back from the weekend it dropped to 40 psi. I have a high volume oil pump and this pretty heavily mild- built.
My thoughts are either I'm not getting enough vacuum to my crankcase or my piston rings aren't doing the job. I had this rebuilt before because my rings never seated. Any suggestion? Also the oil is pretty black and has a burn-your-eyes effect when idling and blows black smoke and loses power @5600 rpm.. When it should be peaking around 6000.
Old May 3, 2011 | 02:37 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Rebuilt engine seeming to go through a lot of oil
The oil pressure has nothing to do with the oil level.
Old May 3, 2011 | 09:00 AM
iroc-z_23's Avatar
Engine: 355 SBC
What would explain my drop in oil level then? Everytime my psi gets low, so does the oil level
Old May 3, 2011 | 10:11 AM
StrahlZ28's Avatar
Car: 1991 Z/28
You have a bad intake gasket? I know this was a common problem on 5.9 Dodge motors and it resulted in fouled oil and heavy oil consumption. (I know this is a Camaro forum and you're talking about a SBC I'm just using the 5.9 as an example)
How much oil did it eat? And an easy way to check for the sucked intake gasket is pull your PCV tube and feel for vacuum at the hole on the valve cover.
It doesn't surprise me the oil pressure dropped. An engine does lose a little after it warms up but 30psi is a little extreme. Is it the factory gauge or an aftermarket one? Because the Factory gauge will pretty much just tell you you have oil pressure or not, it's not very accurate.
Old May 3, 2011 | 11:55 AM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
Doesn't oil psi rise and fall with rpms?
How are you checking you oil level?
Old May 3, 2011 | 11:57 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Burning eyes and black smoke is a sign of an obscenely rich mixture. I'd deal with that before any oil-burning issues.
Old May 3, 2011 | 10:50 PM
iroc-z_23's Avatar
Engine: 355 SBC
It's a fairly new intake gasket? Idk if that's a problem but I'll check. I have an auto meter gauge. AFR reads more lean than it does rich.
Oil psi normally rise 10-20 psi when I'm driving regardless of what the psi is at idle. But I know one time it got to 10 psi and didn't change much. I'm checking Oil on the factory dip stick. But if my rings aren't sealing, gas and oil are going to mix, but I have no blue smoke so idk. That problem might be my 6.5 powervalves as far as burning the eyes
italiano67
Dec 11, 2016 09:21 AM
Reddeath210
Oct 6, 2015 08:20 AM
backtothe80s
Sep 5, 2015 12:39 AM
Navy8125
Aug 21, 2015 09:32 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
