5.0 Tpi Misfire, poss fuel issue????
Car: 1986 IROC-Z
Ok so my car had a little misfire from a few burnt sparkplug wires. I replaced the wires with some bwd's, installed delco plugs, stock replacement cap and rotor and a spare new coil i had laying around. The car ran beautiful for a few weeks.
Then the car sat for about two months. After that i had a hard time starting it, long cranks, sometimes even having to tap the gas pedal just to get it started. Then it got worse, misfiring at idle...then misfiring at take off.
Now it wont stay idling misfires horribly bad at take off, and at higher throttle and speeds it starts surging..sometimes...At startup its even putting out some smoke beyond the little bit of valve seal leak it gets.
Driving me CRAZY!!!! Its even getting horrible mpg now.
Seriously, i need some help, any ideas
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: 5.0 Tpi Misfire, poss fuel issue????
Hook up a fuel gauge at the rails and check the fuel pressure. If you haven't replaced it in a while, also replace the fuel filter.
Iroc8t8
May 4, 2026 08:09 PM
NBrehm
Aug 25, 2015 11:49 PM
beachrodder
Aug 25, 2015 08:05 AM
R3500
Aug 17, 2015 12:16 PM
Sanjay
Aug 12, 2015 03:41 PM
