Car will not start (details) [URGENT]
Old May 3, 2011 | 06:27 PM
Jordan87TA's Avatar
Hello, this past Sunday I was going to take a friend to work, I started my car and backed it out of the garage, the car started fine and idled fine. Everything was normal. I took it to the end of the driveway waiting for my friend. I put the car in park, and then I shut off the engine, not more then 5 minutes later my friend comes outside and go to start up the engine, but absolutely nothing happens. I don't get anything it is a dead silence, I will get one click and after that nothing at all, The lights and everything all power on, the battery is good I had it tested, I tested the starter and it was returned good. I check all my fuse son the inside of my car and they are all just fine. I am completely baffled on why my car went form running fine to dead in a matter of minutes. Please help, thank you.
Old May 3, 2011 | 06:38 PM
NY87Iroc's Avatar
Car: 1987 Iroc convertible
Axle/Gears: 3.42 posi
Re: Car will not start (details) [URGENT]
make sure your battery cables are clean and tight
Old May 3, 2011 | 06:41 PM
Jordan87TA's Avatar
I did this as well, a long with the starter cables.
Old May 3, 2011 | 06:59 PM
'87IROCZOWNER69's Avatar
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
Does the fuel pump still prime when you turn the key to the on position?
Old May 3, 2011 | 07:10 PM
Jordan87TA's Avatar
Yes, everything works except the engine, All of the lights and stuff works, The engine just wont turn or even attempt to turn.
Old May 3, 2011 | 07:18 PM
NY87Iroc's Avatar
tpi?
Old May 3, 2011 | 07:27 PM
ahankins32984's Avatar
Car: 1986 Camaro Z28
Engine: 5.0 305 TPI
Axle/Gears: posi 3.73
is it even trying to turn over???
Old May 3, 2011 | 07:28 PM
Engine: 5.0 305 TPI
check the Alternator and Timing so Distributor/Plugs
Old May 3, 2011 | 07:33 PM
Engine: 5.0 305 TPI
alsot if the alternator is good then it could be a ignition switch gone bad!!!!
Old May 3, 2011 | 07:40 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Here's a diagnosis guide - ignore the VATS stuff since you don't have VATS: http://www.austinthirdgen.org/index.php?pid=38
Chjances are, you have an issue with your purple starter wire, or the nuetral safety switch, or the ignition switch (NOT the key cylinder - the ign switch is on top of the column under the gauges, you have to remove two large nuts and allow the column to drop to get to it).
Camaro305SB's Avatar
Car: 87 Camaro
Engine: 305 LG4 (H)
Sounds like a battery. Autozone tests sometimes test good, but the battery could still have a bad cell. Wouldn't be a neutral safety switch since it clicks.... I really think its a battery or battery cable.
The starting system is just the battery, cables, and starter. The problem is somewhere in there.
Old May 3, 2011 | 07:55 PM
Jordan87TA's Avatar
Yes it is TPi. no its not even turning over, I dont think the alternator is bad nor the batery the cables all seem to be good and free of corrosion.
Old May 3, 2011 | 08:00 PM
Jordan87TA's Avatar
Btw everything else works, lights, interior lights, radio, turn signals brake lights, if it was the battery wouldnt all of that stuff not work either?
midge54
Dec 27, 2019 04:14 PM
colton_carlson
Mar 8, 2019 12:21 PM
Wade787b
Sep 29, 2015 01:15 PM
kyleb24
Aug 15, 2015 08:24 AM
killer777
Aug 8, 2015 02:47 PM
