Engine issues not firing right
Old May 4, 2011 | 12:59 PM
ZEXY's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: TPI 350
Transmission: Brog-warner 5 speed
Axle/Gears: Borg-Warner 9 bolt 3.45 posi
CAR - 1988 Firebird Formula 350 TPI
So it started about a week ago be driving down the road and it will miss.
The tach will jump say from 1800 to about 2400 and then back to 1800 real fast. then as the engine starts to warm up it gets worse the tach will repeatly jump and the engine starts what seems like its missing. But as soon as you let off the gas or step in to it it goes away and is fine only happens at about 10 - 15% throttle which is were cruzing is.
I thought tune up so new rotor, cap, wires, plugs, and its still doing it seem to calm down a little but went right back to doing about a day later some ideas as to what to look in to next
Old May 4, 2011 | 11:09 PM
ZEXY's Avatar
Engine: TPI 350
Re: Engine issues not firing right
Some one has to know whats going on or maybe an idea that i can look in to this is killing my power and fuel milage im sure off it if you need more information let me know what it is ill do the best i can thanks
Old May 4, 2011 | 11:11 PM
88sporty's Avatar
Car: 1988 sport coupe
Engine: 305 swap
have you had the ignition module tested?
Old May 4, 2011 | 11:32 PM
ZEXY's Avatar
Engine: TPI 350
no i havent ... the car did this once before i did a tune up on it and it went away for a year or year and a half then about a week ago it started up again but a tune up didnt fix it this time
Old May 5, 2011 | 01:11 AM
bjm1206's Avatar
any codes? possibly knock sensor or electronic spark control. also when my fuel pump went out the car would idle just fine but when i would accelerate a little while driving it would surge like crazy
Jae992
Aug 27, 2015 09:07 AM
TheExaminer
Aug 26, 2015 04:59 PM
TheExaminer
Aug 19, 2015 10:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
djmarch
Aug 9, 2015 05:27 PM
