fan problem
Old May 8, 2011 | 06:17 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
fan problem
OK,my secondary fan(pass. side) no longer comes on when i use my fan switch. (I've had it wired to an on/off switch for a few years now) Anyhow, if i pop the hood and gently tap the fan it comes on. If i tap it a little harder it goes full speed like it should. Any ideas? Relay or wiring maybe?
Old May 8, 2011 | 06:27 PM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
Re: fan problem
Does it stay on after you tap it?
bad connection somewhere in the circuit maybe
Old May 8, 2011 | 07:14 PM
ninetyone's Avatar
Axle/Gears: 3:42
Re: fan problem
will stay on until i shut off car, then i have to tap it again .
Old May 8, 2011 | 07:15 PM
ninetyone's Avatar
Axle/Gears: 3:42
Re: fan problem
what circuit? inside the fan? Does tapping on the fan itself rule out a bad fan relay?
Old May 8, 2011 | 08:20 PM
Curious_George's Avatar
Car: '87 IROC, '92 & 99 Corvette Vert.
Engine: L98, LT1, LS1
Transmission: L98 = 700R4
Axle/Gears: L98 = 3.23 G92
Re: fan problem
I would say the fan is intermittent (bad). Especially, if you tap on it, and it runs briefly.
CG
Old May 9, 2011 | 07:49 PM
ninetyone's Avatar
Axle/Gears: 3:42
Re: fan problem
Turned out to be a bad relay.
Old May 9, 2011 | 08:31 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
Re: fan problem
I was burning up relays till I replaced the pig. There was a bad connection that caused heat to build up, and the relay fried. You may want to check your old relay for signs of excess heat.
Old May 9, 2011 | 08:41 PM
Re: fan problem
This is true... if the connector / pigtail is not making a good connection and arcing intermittently, then this will cause tremendous heat build up and damage the relay.
CG
Old May 9, 2011 | 08:51 PM
ninetyone's Avatar
Axle/Gears: 3:42
Re: fan problem
What do you mean by checking the old relay? I switched relays and it works perfectly now.
Old May 9, 2011 | 09:06 PM
Re: fan problem
I should have elaborated more. My old relay had brown on the plastic around 2 of the connections. The brown meant too much heat from resistance. I noticed it after my second relay. It was fried, and it had the same heat scorch marks. The pig had some meltage around the connections that mated to the relay. After the new pig install, the relay didn't burn out.
Old May 9, 2011 | 09:08 PM
ninetyone's Avatar
Axle/Gears: 3:42
Re: fan problem
oh, mine seems to appear ok.
krisner89
Oct 10, 2015 06:03 AM
utfan01ss
Sep 28, 2015 12:17 PM
Papaginos
Sep 27, 2015 03:29 PM
JHX
Aug 29, 2015 02:30 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
