ATF in manual transmission???
Old May 10, 2011 | 06:27 PM
tylerandtony's Avatar
'84 Firebird S/E, 2.8L V6, 5 Speed manual transmission.
I have two questions on this car.
1- We have a single clunking sound from the rear when you take the car out of gear when coasting and/or when we put it into reverse gear, but only once on each occasion.
UV joints have been replaced. Bearings look good. Rear end differencial was low on gear oil, in which we filled it up to what it was supposed to be at.
After talking with the previous owner's last week, he told us that he had put ATF in the tranny because it was low. When my husband looked at it, it was milky looking.
Question is...............ATF in a manual transmission? What is causing the clunk sound?
2- Front headlights............UGH!!!
Driver side will not go up, but if you put it up manually, it will go down.
Passenger side will not go up or down, only manually.
Isolation relay shows no power in pink, blue and blue w/stripe wires when needed.
Relays have been changed, and so have the motors along with the interior switch.
No modular near firewall as someone had mentioned.
Please HELP!! We are going nuts here with this car!!
Old May 10, 2011 | 06:36 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: ATF in manual transmission???
Welcome to TGO.
ATF can be used in T-5's. Check the following link for more info about that crazy business:
https://www.thirdgen.org/forums/tran...ything-we.html
As for the clunk, a common problem is the trans mount.
Questions about the headlight might be better addressed in the electronics forum.
Best of luck with your projects.
JamesC
Hotrodboba400
Dec 10, 2019 07:07 PM
Nick McCardle
Sep 10, 2015 08:36 PM
angel2794
Sep 8, 2015 06:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
