Hard to turn right
Old May 18, 2011 | 06:13 PM
MrPresident's Avatar
Hard to turn right
Just replaced the steering pump and gear box last week and never really tested it.
The steering wheel is off(turned left to about10-11 oclock), but I was told on another thread I just need to get a toe adjustment.
My problem is I need to use more strength to go right, its not hard, but when I turn left its barely any strength.
Could there still be air in the system?
Old May 18, 2011 | 06:31 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: Hard to turn right
Yes there could be air in the system. Because the pump is above the gear, it should work itself out. You could also have a defective gear or a bind in your steering linkage or front suspension.
Old May 18, 2011 | 07:21 PM
Good thing I kept receipts. Hopefully the mechanic can tell me if its defective or if its something else like you suggested. Thanks
Fronzizzle
Mar 18, 2019 08:29 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
