Switch Issue
Old May 18, 2011 | 06:59 PM
ailotea's Avatar
Switch Issue
I inhereted a 86 firebird that needs some work to say the least. i hooked a battery up and decided to see if it would crank/ start. The ignition switch will advance into the on position with ease but will not go to start position. Any ideas?
Old May 18, 2011 | 09:10 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Switch Issue
The actual switch is above the steering column, under the guages. The key cylinder when turned pushes a rod into the actual switch. It's possible the switch is bad, or the rod has becomed dislodged from the switch. Is it an automatic? If so, there's also a cable that runs into the ignition switch that won't allow the car to be turned to start unless fully in park or neutral.
To get to the actual switch, remove underdash panel, remove the bracket that holds up the underdash panel, then remove the two large buts that hold the steering column up to the dash, and allow the column to fall down (the wire bundles will hold it up off the floor). Then you can see the switch on top of the column.
Old May 22, 2011 | 12:56 PM
ailotea's Avatar
Re: Switch Issue
It is a manual and thank you i will try to fix it asap.
Street Lethal
Apr 30, 2019 12:14 PM
PATRIOTIC1911
Sep 1, 2015 07:26 PM
355sbcTPI
Aug 19, 2015 04:38 PM
Bryan F
Aug 18, 2015 02:28 PM
djmarch
Aug 9, 2015 05:27 PM
