1986 Camaro 305 Carb WONT START
Old Mar 11, 2010 | 01:07 PM
MetallicaWolfe's Avatar
Car: 1986 Berlinetta Camaro
Engine: 350 SWAP
Axle/Gears: Stock
Ok so heres the deal. My car wont start. Fix it. Kthanxbai
Anyway lol, So Ive changed out the computer controlled distributer & the quadrajet, now edlebrock 1406. It now has a new starter aswell. We have it top dead center & all that swell stuff but it wont start. When you turn the key its just nice & smooth(love the new starter lmao) but it wont ****ing start. It also has a new coil on the cap & new battery.
On top of all that when you put the new timing light doesnt work on it but the timing light is just fine because we tested it on a different vehicle and walla it works. So I was told it could be the ECM? What else would cause my camaro not to start, its really bugging the **** out of me & spring break is next week, would hate to waste it sitting at home. Thanks!
Old Mar 11, 2010 | 02:47 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You don't have spark. Without spark, it won't trigger the timing light and won't ignite the fuel/air mixture.
Verify your hookups, that you have power to the coil, etc.
When you took off the q-jet and replaced the distributor, you took the ECM out of the equation.
Sorry to hear you removed the best street performance system out there for this downgrade.
Old Mar 11, 2010 | 02:59 PM
Engine: 350 SWAP
Axle/Gears: Stock
Re: 1986 Camaro 305 Carb WONT START
Ooo that totally didnt enter my mind, sweet no ecm worries. More like removed a pain in the ***. Anyway I'm getting spark, forgot to mention that so the next thing would be the ingnition module on the new distributer, what do you think?
Old Mar 11, 2010 | 03:12 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
so then the engine does turn over when you turn the key, it just doesn't fire up?..... well makes sure you're getting fire at the number 1 cylinder, pull the boot off and check it there... just because the coil is new doesn't mean you got a working one... if you have the old one, throw it on and see what happens...
Old Mar 11, 2010 | 03:31 PM
Engine: 350 SWAP
Axle/Gears: Stock
Yes it turns over but doesnt, "start"
It is getting fire, is it possible not getting enough spark to start up?
Old Mar 11, 2010 | 03:53 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
have you tried carb fluid? maybe the carb is not getting primed... I don't know I am "blank" ...
Old Mar 11, 2010 | 03:57 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
what about the carbs jets, did you do the primary adjustment or is this done from the factory? You can close the jets all the way right? preventing fuel from entering or not? I remember on my Electronic Quadra-Junk, closing the jets and my car stalling and not starting until I opened up a little....
Old Mar 11, 2010 | 04:50 PM
five7kid's Avatar
Let's back up here before something or someone gets damaged. Set the can of starting fluid down and back away.
Have you taken a spark plug wire off of a spark plug, put in near a ground and cranked it over to look for spark? Another way is to put a spark plug on the wire, put the plug on a good ground, and turn it over and watch for the plug sparking.
You do understand that the #1 piston comes to TDC twice in one rotation of the distributor, right? In other words, when the #1 piston is at TDC, the engine is either on the #1 or #6 firing position.
Do you know whether or not you have gas in the carb?
Old Mar 13, 2010 | 04:57 PM
Engine: 350 SWAP
Axle/Gears: Stock
Actually I got it started a few times yesterday but the problem is I come back & it wouldnt start again so I leave it be. After work today I come home try it again, wala! It runs again, let it run, turn it off, come back out wont start!? Whats the deal????
Old Mar 13, 2010 | 07:03 PM
Engine: 350 SWAP
Axle/Gears: Stock
Ive also had the distributer replaced, the new one. So whats the chances of both being bad and working at random?
Old Mar 15, 2010 | 06:53 PM
Engine: 350 SWAP
Axle/Gears: Stock
For the 3rd day in a row it starts again, havent tried again but if its like it has been it wont start till tomorrow, whats the deal? It starts and runs fine, its just when turned off wont start again, or only start a few more times then nothing?
Old Mar 15, 2010 | 07:30 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
let's update your list of things you have replace... have you checked the ignition module? you say you replaced the distributor, did it come with a new module? since you bypassed the computer, your distributor is now mechanical advance right?
Old Mar 15, 2010 | 07:35 PM
Engine: 350 SWAP
Axle/Gears: Stock
Yea replaced same distrib twice now so Im not thinking its that, got it started like 6 times so im thinking its something else, yea vaccum distrib, new starter and solenoid, new battery, fuel pump is fairly new etc
Old Mar 15, 2010 | 07:36 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
fuel pump electric in tank? or mechanical on block?
Old Mar 15, 2010 | 08:39 PM
Engine: 350 SWAP
Axle/Gears: Stock
mechanical block what else you wanna know?
Old Apr 16, 2010 | 06:40 AM
Engine: 350 SWAP
Axle/Gears: Stock
Ayway not to uselessly bump this but I got it finished and tuned weeks and weeks ago, never been happier =]
To all you quadrajet lovers, even after rebuilt after rebuilt on that carb its been pathetic and dont begin to tell me it was the mechanic XD So anyway what I thought was a horribly transmission was 80% carbs fault. Runs like a champ and has never started with so much ease before =]
And it seems mpg has gotten better as well ^^ Seems to smoke alil more on start up but thats a different story =] Wooo!!!
Old Apr 16, 2010 | 10:21 AM
aremy10's Avatar
Car: 91 firebird
Axle/Gears: stock
glad youre "downgrade" from the" best street performance system" worked ,,,,, just kidding, good ole edlebrock
Old May 22, 2011 | 01:27 PM
Odydog6's Avatar
Transmission: 700R4 (Rebuilt)
Re: 1986 Camaro 305 TPI WONT START
y
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
theshackle
Mar 5, 2017 06:37 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
