2 unrelated questions
Old May 18, 2011 | 08:01 PM
Aldudley5's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
91 RS 305 TBI
First:
From the factory was there a spacer between the air cleaner and intake? If so, how tall was it? I've had my car for a little over a month with no issues, and today the cleaner was resting on top of the coil wire causing some fun with electricity.
Second:
What is this rusty box? it is located on the driver's side next to the radiator under air snorkel intake. It has one green wire coming from the hood pin switch(?). it is really loose, and if you tap it and stop it from moving there is something inside that keeps moving like it is on a spring.
Old May 18, 2011 | 08:41 PM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Re: 2 unrelated questions
bump, would like to know also. I have the tbi in a 91, I don't recognise the part.
Old May 18, 2011 | 08:53 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
The spacer was about 1/2 inch.
The rusty box I've never seen before - it's not from factory.
Old May 19, 2011 | 06:15 PM
Aldudley5's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Thanks.
Anybody else have an idea what this thing could be?
Old May 19, 2011 | 06:37 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I'm going to say motion sensor for an alarm.
Old May 19, 2011 | 06:43 PM
Aldudley5's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
You know, I didn't think of that. It kinda makes sense. Thanks.
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
