Questions on mounting in tank pump - O'Reilly pump seems too small?
Old May 18, 2011 | 11:35 PM
87irocjohn's Avatar
I am converting to an in tank pump. I have the fuel injected hanger/sending unit assembly minus pump. I bought a new fuel pump from O'Reilly.
Looking at the fuel pump from O'Reilly, the diameter looks significantly smaller than the 1/2 circle shaped cradle coming off the return line that it appears that it should be clamped to. The pump looks correct length wise, has a 3/8" outlet that matches the metal line fuel feed line, and the electrical connector matches. Do I have the wrong pump, or are the aftermarket pumps smaller diameter than the stock pump?
If I can use the O'Reilly pump, do I just let it hang by the 3/8" outlet and the strainer support at the end of the hanger, or do I need to do something to clamp it so the body of the pump is supported?
Last, is there a special rubber connector to connect the pump to the metal line or do I just use 3/8" ID fuel line
Thanks in advance.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
mustangman65_79
Apr 14, 2017 05:37 PM
redmaroz
Aug 16, 2015 11:40 PM
TreDeClaw
Aug 14, 2015 06:58 PM
mcquigg
Aug 13, 2015 02:26 PM
