1987 Camaro Iroc-z help me please
Old May 22, 2011 | 01:06 PM
Alpine1987's Avatar
Car: 1987 Camaro Iroc-Z
Engine: 350 5.7
Transmission: 5-speed
Hey i got a 1987 Camaro Iroc-z 5.7 and everything was runing fine but i took of the tpi setup on the to off just to polish it and i put it back on the next day and it started to idle real low but dosnt shut off idles at like 5 just above 5 and before it would idle at 10 so i dont noe whats up im thinking maybe its the IAC but i replaced that to and same thing and i cheaked all my house and every thing but ntn it off and if i take out the MAF sensor plug by the ait filter then it would start to run much better it gose at around like 10 to 15 so please Help Me Thanks.
Old May 22, 2011 | 03:03 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Re: 1987 Camaro Iroc-z help me please
I would try and help but I can't understand what you're saying. Please retype your post, this time using the "." key.
Old May 22, 2011 | 03:28 PM
Alpine1987's Avatar
Engine: 350 5.7
Hey i got a 1987 Camaro Iroc-z 5.7 and everything was runing fine but i took off the tpi setup on the top the engine just to polish it and i put it back on the next day and i started car the idle was real low but dosnt shut off idles at like "5" just above 5 and before it would idle at "10" so i dont noe whats up im thinking maybe its the IAC but i replaced that to and same thing and i cheaked all my house and every thing but ntn is off and if i take out the MAF sensor plug by the air filter then it would start to run much better it gose at around like "10" to "15" so please Help Me Thanks.
Old May 22, 2011 | 07:27 PM
hdis2002's Avatar
Car: 87 IROC Z
Engine: 5.7
If the engine is stock, the idle is supposed to be around 600 or "6". Sounds like you may have fixed something by accident.
Old May 22, 2011 | 08:09 PM
luvmy64's Avatar
Sounds like he may have fixed a vacuum leak. When you were unplugging the MAF, you were putting the computer in "limp home" mode, which may be why it idled up. Someone will correct me if im wrong....
Old May 22, 2011 | 08:20 PM
Alpine1987's Avatar
Engine: 350 5.7
When i start it runs fine and it was a 350 before now its a 350 but stock comp ntn done to prom and it kind of sounds like it will shut down on you when its idle but dosnt if any if this helps
Old May 24, 2011 | 08:13 PM
Cleric69's Avatar
Car: '87 IROC-Z
Engine: 350ci
Transmission: 700r4 rebuilt
My '87 IROC idles around 600-700. It is a carbed 350, not a TPI like yours (was idling around 12-14, but I don't think the PO knew how to tune a carb because my dumb *** did it in the span of 30 minutes when I got it home). It also sounds like a real slow, throaty growl but it stays running. You'll get used to it. Like hdis2002 said, I think you fixed something while you were cleaning stuff up.
My take is this: if you idle down the strip with your engine rumbling like it should and you get panties thrown at you then everything is working as it should. :-)
beachrodder
Aug 25, 2015 08:05 AM
StevenB L98/LS1
Aug 22, 2015 09:03 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
jahblah
Aug 12, 2015 05:54 PM
Fronzizzle
Aug 9, 2015 01:15 PM
