1985 Trans am TPI misfiring and studdering
Old May 23, 2011 | 07:58 PM
95GTTransam's Avatar
I own a 85 trans am 305 TPI, the car is completely stock with the exception of a catback.
Since I bought the car, It has always studdered when it is cold and goes away as soon as it warms up.
However a misfiring issue has started to occur that has me confused.
I simply got in the car one day and started it up and it had a dead miss, so then I let the car sit for awhile. The battery went dead, I charged it up and started it and the Misfire was gone. ( the studder was still there).
So I drove the car for about 3 weeks every day, then all of a sudden I took it out again and felt something was off and by the time i got home it had a dead misfire in it again. The CEL comes on sometimes when it is started and sometimes it doesn't come on. (Regardless if the car is misfiring or not). I just took the battery cable off the car for 30 minutes and put it back on to see if it would fix the problem, but it did not. So I am very confused by this, I can only think that it has to be a sensor of some sort.
I would greatly appreciate it if someone could help me as my other car took a crap on me. Thanks!
Old May 24, 2011 | 07:18 AM
Re: 1985 Trans am TPI misfiring and studdering
Anyone please?
Old May 25, 2011 | 07:09 AM
Not a single person can help me out? Really? -_-
Old May 26, 2011 | 09:03 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
You should be able to use a paperclip to see the codes flash via your CEL.
1. Make sure the key is off
2. Insert hi tech trouble code checker( paper clip bent into a u shape) in A and B. Now let's make sure you are in A and B. If you are looking at the ALDL, A and B are on the top row on the far right. Make sure the paper clip is touching the contacts.
3. Turn the key on/run but don't start the car and leave it there.
4. SES should start flashing. It will flash code 12, 3 times, then start giving you the trouble codes.
Now earlier tpi cars may have used pins A and E vs pins A and B on the GM ALDL port(ALDL is the small black box under drivers side dash beside fuse box) It has 12 holes(pins).
Old May 26, 2011 | 09:07 PM
ninetyone's Avatar
Axle/Gears: 3:42
You only need to disconnect battery cable for like 30 seconds not 30 min.
Old May 26, 2011 | 09:14 PM
ninetyone's Avatar
Axle/Gears: 3:42
Start it up at night and look for blue flashes from your wires (arcs), sound like you have a bad ignition part somewhere. Inspect your dist. cap
Reddeath210
Oct 6, 2015 08:20 AM
Dquickshift
Aug 12, 2015 06:21 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 10, 2015 07:44 AM
drathaar907
Aug 6, 2015 04:20 PM
