Engine would not turn over after power washing
Old May 27, 2011 | 12:12 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
My 92 305 TBI would not crank after I power washed it. After about 20 minutes it started right up. Something must have gotten wet. Any suggestion would be very much appreciated.
Old May 27, 2011 | 12:15 PM
87 player bird's Avatar
Car: 87 player's trans am a4u (pepsi car
Engine: 305 tpi
Transmission: 5 speed
Axle/Gears: 3:42
Re: Engine would not turn over after power washing
Cover your distributer with a plastic bag next time. Being a computer car, I would be very careful with a pressure washer under the hood.
Old May 27, 2011 | 12:23 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I agree. Distributor cap or starter 12v wire wasn't making a good connection
If it continues to fail to crank easily when hot even if you're not washing it that would make me think the starter is beginning to go bad.
Old May 27, 2011 | 02:49 PM
The starter always sounds good when it cranks at what ever temp. I had power to everything except the starter wouldn't crank at all. As if I were trying to start when in drive. I was just washing the car. The hood was closed. I was not power washing the engine.
Vintageracer
Jan 10, 2020 05:33 PM
Caspar
Jun 19, 2016 11:19 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
ZsTransAm
Aug 11, 2015 07:30 PM
