Vortec 350 w Edelbrock 1406 Carb and headers
Old May 29, 2011 | 08:24 PM
meadmarc's Avatar
Car: 89 Formula Firebird
Engine: 350 Vortec
Axle/Gears: 3.73 posi
I have a 1997 Vortec 350 (truck engine) that I would like to rebuild and put in my 89 Firebird (in place of my 305 TBI). Should be a pretty stock rebuild, for the most part, I was going to replace the existing spider fuel injection with an Edelbrock Performer intake, with a 1405 Carb. New vacuum distributor, of course. And I have a set of Summit shorty headers, the cat has already been removed and I have no plans to replace it.
1. What kind of FWHP do you think this will put out? I'd like to hit 300, the stock motor was supposed to be good for 255.
2. What kind of HW MPG can I expect?
3. Are there any other modifications I should consider while rebuilding? I had looked at cams briefly, but I kept hitting the "and then you get bigger valves, and machine this, and replace the springs, and oh-yeah-now-between-the-cam-and-all-this it's another $800" wall. Anything that DOESN'T invlove dramatically re-working the stock heads, which I understand are quite good already?
THANKS!
Last edited by meadmarc; May 29, 2011 at 08:25 PM. Reason: It was a 1405, not 1406...
Old May 29, 2011 | 11:05 PM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
Re: Vortec 350 w Edelbrock 1406 Carb and headers
When you have the heads rebuilt they can/will cut them for larger lift cam if you ask them to.
Old May 30, 2011 | 06:01 AM
meadmarc's Avatar
Engine: 350 Vortec
I'm don't think I'll get much further than pressure-checking the heads. They should be okay, the problem with the engine was a spun bearing, and I need to keep the rebuild as inexpensive as possible or it will never happen.
If they need to be torn down, then I could possibly look at that, but adding a new cam, valves, and springs (and possibly lifters), it gets expensive quick.
A friend of mine who has been building/racing cars for decades told me the cam in the stock Vortec was actually pretty good, and based on what I was shooting for, not to worry about replacing it.
Old May 30, 2011 | 08:36 AM
Guest
Guest
Posts: n/a
I think I'd just install a stock LT1 cam. No machining required. Bolts right in.
How are we to guess your MPG potential without knowing your transmission, your axle ratio, and your rear tire size?
Old May 30, 2011 | 09:31 AM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
If the motors gonna be rebuilt, that's the best time to do a cam. I spent under 200 bucks for my flat tapper cam, lifters, pushrods. I did however have the machine shop install better valve springs that I had.
Those heads are worth improving though, and now would be the time to do it.
MPGs and carbs don't really go together, but I can get 13 maybe on the highway. You won't need anything bigger than a 650 on a 350.
Old May 30, 2011 | 09:59 AM
Guest
Guest
Posts: n/a
I've done repeated 27 MPG trips with the carb'd 350 in my '86 IROC-Z that I used to have, so don't accept 13 mpg.
Old May 30, 2011 | 11:22 AM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
If you can tell me the secrets of a 22 mpg trip I would be happy
Old May 30, 2011 | 01:55 PM
Guest
Guest
Posts: n/a
I sent you a PM so as to avoid hijacking the thread.
Old May 30, 2011 | 04:29 PM
meadmarc's Avatar
Engine: 350 Vortec
My bad, try to keep the posts short. 700R4. 3.42. Stock 16".
As far as the LT1 cam, I had thought that, but the aforementioned mechanic told me that the Vortec heads are very close to the LT1 heads, and that the Vortec truck cam was effectively the same as the LT1 cam. He then called his speed-shop connections and they confirmed.
Is that not correct? Time to go pick up a used LT1 cam?
Old May 30, 2011 | 04:31 PM
meadmarc's Avatar
Engine: 350 Vortec
That was what I was hoping. Mid 20's would be very satisfactory. With headers and the Edelbrock intake, that sound reasonable?
Old May 30, 2011 | 07:59 PM
Guest
Guest
Posts: n/a
The L31 cam is 191 intake duration, while the LT1 cams are in the 203 range. Not a huge difference. Similar situation with the lift. The LT1 has a couple of hundredths more lift. But the difference in useable rpm range is at least another 500 for the LT1 cam.
Price it, then decide for yourself. I've driven an L31 FS 1/2-ton pickup, and I've driven an LT1 Impala SS. I'd definitely swap cams.
Your combo isn't so far from what I had success with, mid 20s for MPG should be possible, if you can dial in your fuel and spark.
Old May 30, 2011 | 08:43 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Nope that is intake/exhaust/compression ratio/tuning differences between those engines.
The iron head LT1 has the very same camshaft as the L30/L31 truck/van engines do. Its the F/Y- car LT1s that have the larger camshaft. The B-car engine has 260 HP and 330 TQ compared to the 285-305 and 340 of the hotter engines. The timing maps are vastly different as well. Vortec trucks only run about 22* BTDC, B-car LT1 about 29*BTDC and F/Y cars run 33* BTDC. The advance curves are also vastly different.
Old May 30, 2011 | 10:22 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Your mechanic is actually about right... the Vortec heads are very close to the LT1 heads. They're actually an improvement on the LT1 heads in a lot of ways, but they are related. The cams arent what I would consider that close to each other, but I can see how that would be a subjective judgment in some people's eyes. I'd suggest getting a decent mild aftermarket roller cam... or an LT4 hotcam. That would require a little work on your heads, but I think it would be more than worth it. A nice roller cam in a vortec headed engine is the difference between 250hp to the wheels and a 350hp to the wheels.
Old May 31, 2011 | 04:44 AM
meadmarc's Avatar
Engine: 350 Vortec
I know cam brands can become a religious debate rather quickly, but any specific recommendations that would hopefully allow me to re-use the rollers and lifters?
Old May 31, 2011 | 08:17 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
lt4 hotcam
simple swap. Have the heads worked correctly for the extra lift. Any machine shop that is even half decent knows what needs to be done.
I drove my car with the stock vortec motor for awhile. Then went to the lt4 hotcam. Night and day difference. Went from running a 9.28 to an 8.50 with a cam swap and tuning.
It will require a stall converter to get full potential.
Old May 31, 2011 | 08:27 AM
Guest
Guest
Posts: n/a
No, the Camaro was 275 HP, while the Impala was 260 HP, because of the intake and exhaust systems. The iron LT1 heads had slightly better intake ports, but used the same cam as the Camaro.
The pickups actually had the best exhaust flow, because of the extra space underneath for freedom of routing.
theshackle
Sep 17, 2020 08:26 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
matthew911
Aug 12, 2015 09:38 AM
