Full roller rocker arms
Old May 30, 2011 | 11:07 PM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
Before I pull the trigger on a set of full roller rocker arms I got a few questions.
1) is there any advantage between an aluminum set vs. steel vs. stainless steel?
2) does the difference between 1.5 and 1.6 really make any noticeable difference in performance?
3) with factory heads, do I need to use self aligning arms? The 350 I'm running now came with them ('91 flat tappet cam truck block) whereas the original 305 did not ('87 roller cam LG4). It has a comp xe262 Flat tappet now, and I've been using the stamped rockers that came with the 350.
Old May 30, 2011 | 11:34 PM
87hellbird's Avatar
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
Re: Full roller rocker arms
yes the different size rockers will affect overall performance by enough to feel. i had some 1.7s roller rockers on my 305 tpi and it nearly doubled my idle speed from 800 to 1500. idont really know the difference between the type of metals other then the aluminum would be lighter and in turn easier on ur cam. and with roller rockers for making sure they set right u mostly just want to make sure the part the touches on the roller should be in the center of the valve stem
Old May 31, 2011 | 12:37 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
I've seen depends on the brand. DO NOT BUY PROFORM rocker arms. Period.! You need self aligning rocker arms. A lot of people like scorpion rocker arms. I like the comp pro magnum steel rockers. harland sharp has a good name. I think steel is deffinately stronger obviously. But if its a weekend car, or a track only car. Then you can go aluminum. Guys have been running aluminum's for years. Good luck with it. 1.6 over 1.5 for more valve lift. that alone should not raise your engine rpm's.
morrow
Jan 13, 2024 12:29 PM
midge54
Dec 27, 2019 04:14 PM
92projectcamaro
Jan 18, 2016 08:00 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
IrocZ'85
Aug 17, 2015 06:24 PM
