will valve seals cause this
Old May 31, 2011 | 05:26 PM
stevek's Avatar
Car: 1989 GTA
Engine: 5.7 /360
Transmission: turbo 350
Axle/Gears: stock
Students recently "overhauled" my heads and I noticed on start-up, I always get a big blue puff of smoke and it sounds like my plugs are fouled. Sometime it clears up and sometimes it keeps smoking as I rev it up. After the job was done the kid forgot to put in the new springs so he disassembled and reassembled them.Someone suggested that it may be the valve seals.Anyone have any input? thanks
Old May 31, 2011 | 09:00 PM
torque_is_good's Avatar
Re: will valve seals cause this
remove heads
bring to a shop and pay for a proper valve job including new guides
install new head gaskets
reinstall heads
Old Jun 1, 2011 | 10:04 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Students work for free, but in the end it will cost you more than you saved.
They either didn't even put the valve seals in, or they forgot some of them because more then one kid took a turn, but most likely they damaged the seals when they installed them.
Bubbajones_ya
Jul 6, 2024 08:32 PM
355tpipickup
Sep 13, 2015 11:35 PM
bamaboy0323
Sep 12, 2015 07:14 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
tgp1990
Sep 4, 2015 06:24 AM
