91-92 350 is running on 7 cylinders
Old Jun 2, 2011 | 04:09 PM
Mpaul3355's Avatar
Title explains it all I'm looking at a 91 or 92 camaro with a 350 and it is suposiple running on 7 cylinders any suggestions ?
Old Jun 2, 2011 | 04:15 PM
futureBAirocz's Avatar
Re: 91-92 350 is running on 7 cylinders
Check your plug wires see any of them burnt threw or something. my friend had same prob and one of his wires got burnt threw on head. check if all plugs are getting spark too
Old Jun 2, 2011 | 04:23 PM
Mpaul3355's Avatar
Oh ok well it has a 5 speed and 350 and it needs a clutch( won't go in any gear) and running on sever cylinders so if it's small it's good I mean the guy wants 700 for it so I can't see it not being worth it I think
Old Jun 3, 2011 | 09:07 AM
torque_is_good's Avatar
if you are looking for a project vehicle that you have every intention of spending a few thousand dollars to fix then go look at it. What you describe is a "roller"
I paid $500 for a RUNNING 89 RS with a 305 with zero rust. I have just about finished the restoration/complete rebuild.
If you are looking to get a daily driver from this car and hope a few bucks will fix it.......run away real fast. 7 cylinders???? How do you know? Did the seller tell you? If it was just a plug wire then the seller would have replaced it.
As for the clutch being bad, will it not even go into any gear?
honestly, that's a project car that you're looking at and not one that you'll buy and have on the road for a couple hundred bucks
Old Jun 3, 2011 | 11:55 AM
galvarado's Avatar
Car: 88 Camaro SC
Engine: Aluminum Vortec headed 383 roller
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt/3.27
Is it carbureted, throttle body injection, tuned port injection....?
Old Jun 3, 2011 | 07:15 PM
Mpaul3355's Avatar
Im not a 100% sure
Old Jun 3, 2011 | 11:35 PM
galvarado's Avatar
Car: 88 Camaro SC
What does the induction system look like? Depending on what you have, it could rule out/rule in certain problems.
Old Jun 3, 2011 | 11:55 PM
'87IROCZOWNER69's Avatar
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
I bought my 87 Iroc with the 350 when it was running on 7 cylinders, of course I didnt know it was when I bought it and I bought it from a dealership. A few days ago I replaced all the plugs and wires and wallah it runs HARD. I have put 100 miles on it in those few days because its so much fun and I still have over a quarter of a tank and all I have done is race the darn thing (I refilled it after I fixed it)!
Frozer!!!
Jan 19, 2024 04:55 PM
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
NinjaNife
Aug 23, 2015 11:49 AM
db057
Aug 22, 2015 08:17 PM
Burnt.Clutch
Camaros Wanted
Aug 21, 2015 11:11 PM
