How to tell if you have a TBI or TPI
Old Jun 2, 2011 | 06:48 PM
JordanMonde's Avatar
Car: 1992 RS Camaro
Just got new car, how can I tell. And I dont have the stock engine in it
Old Jun 2, 2011 | 06:53 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Re: How to tell if you have a TBI or TPI
Old Jun 2, 2011 | 07:08 PM
Car: 1992 RS Camaro
Old Jun 2, 2011 | 07:09 PM
Car: 1992 RS Camaro
thats what i got
Old Jun 2, 2011 | 07:16 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
You have a TBI. with a upside down air cleaner lid.
Old Jun 2, 2011 | 07:24 PM
Car: 1992 RS Camaro
yea i know its upsidedown i fixed it after pic
Old Jun 3, 2011 | 08:40 AM
torque_is_good's Avatar
how do you know it's not the "stock engine"?
did the seller tell you it's a "350" ?
get the castings off of the block and look up the numbers.
that's a tbi that you have there and it looks pretty stock to me
Old Jun 3, 2011 | 08:44 AM
https://www.thirdgen.org/forums/memb...storation.html
in that thread is a picture of a rebuilt 305 tbi made to look pretty and headers added
some vandal went wild with blue paint
Old Jun 3, 2011 | 09:41 PM
Car: 1992 RS Camaro
because its a v6 car wit a v8 engine
Old Jun 3, 2011 | 09:52 PM
chris.niemann84's Avatar
Car: 1985 IROC Z28
Engine: L98 - 350/650 Holley DP
Axle/Gears: 3:83 Full Spooled
thats not a 350 from my 27 yrs of past
350 has the A/C on the other side of the motor
*before i get "your wrongs" i know years mattered but to an extent they didn't. 350's had a/c on driver side from 83-97 unless you put on the modified aluminum surp. bracket
1987 - 350 carb'd in a 1985 IROC that had a 305tpi
Old Jun 3, 2011 | 09:55 PM
Car: 1992 RS Camaro
i never said i had a 350 i no i have a 305 i was just wondering bout tpi and tbi
Old Jun 3, 2011 | 09:57 PM
Car: 1985 IROC Z28
ok then... i figured that was an easy one hence the names......
THROTTLE BODY injection
TUNED PORT injection
only one looks like it has a throttle body like a carburetor and only one has "ports"
sorry for the misunderstanding
Old Jun 4, 2011 | 04:02 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
TPI has a throttle body. Ports can mean anything. You think runners look like "ports"?
That means nothing. All the belt systems will bolt up to all the heads and the block has nothing do with which side's cylinder head gets the air conditioner. From what I recall the A/C got moved over to the driver's side the last few years of thirdgen production for v8s, regardless of whether it was a 350 or not. Before then all the V8s were 305's. Im thinking 87-92ish the A/C is on the passenger side, but it may be 88-92.
Are you implying that GM has otherwise identical engines in the L98 and the LB9 and intentionally used different serpentine brackets, for no other reason, than to differentiate between the bore diameters in the block?
Old Jun 4, 2011 | 04:49 AM
jeff_blake's Avatar
Car: 86 Iroc + 83 Firebird
Engine: Iroc 305 TPI, Firebird 305 4bbl
Transmission: 700r4 in both.
Axle/Gears: Iroc 3.27 Firebird 3.23
I want to say ac on the passenger side was an 88-92 thing. may be wrong though..
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
evilstuie
Jan 9, 2020 08:29 PM
Dwayne614
Sep 28, 2015 08:33 AM
Sanjay
Aug 12, 2015 03:41 PM
