stalling problems
Old Jun 4, 2011 | 08:20 AM
nova1396's Avatar
stalling problems
every time i start the engine when its cold it will fire right up but then stall right away.it does this a couple of times before it stays running. i have checked the cold start injector its not that because it fires right up with it plugged in but wont start with it unplugged . i have done all the adjustments to the iac and tps .would the cts have anything to do with this problem i dont have the radiator hooked up. this engine is on a test stand.and also the esc 4 wire plug on the distributor when i unplug that to set the base timing the engine wont fire. this is an 86 tpi setup with painless harness 165 ecm with a non emissions burnt chip. any help would be great. i cant figure this out.
Old Jun 7, 2011 | 09:18 AM
nova1396's Avatar
Re: stalling problems
is there anybody that might no what the problem is. anything so i can try to get this ready to swap in my blazer. please
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Bryan F
Aug 27, 2015 07:28 AM
Bryan F
Aug 18, 2015 02:28 PM
92camaroJoe
Aug 13, 2015 06:07 AM
