Sensor info and location help!!!!
Car: 1988 pontiac Trans Am GTA
Engine: DFI,Single Plane,200cc Dart I.E,355
Transmission: Th400 PTC converter
Axle/Gears: Stock Ausie 9 bolt w/3.45 gears
Well after 5 years I am finally putting my motor back together and I can't seem to identify this sensor or where it goes. I figured it was another oil pressure sending unit for the ecm but not 100% sure. I also thought that it screwed into the block right above the Oil filter and it doesn't seem to thread into the hole that is there..so any help would be appreciated..thanks...also the car is an 88 trans am gta.
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG] Thread Starter
Re: Sensor info and location help!!!!
Found my answer
9192camaro
16
Feb 3, 2019 12:21 AM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
